Discussion topic: Ethernet connection shows wrong broadband provider
Message posted on 06 Jan 2025 09:15 PM
Evening
We've just had Sky Q re installed (reverted back from Sky stream), I've noticed that when looking under the network settings it was showing as an Ethernet connection but the ISP showed Sky. We don't have Sky broadband, we have BT. I've just changed the connection to WiFi and chosen our own network. Really want it connected by Ethernet. How can it show a connection to an ISP we don't have?
Message posted on 06 Jan 2025 09:28 PM
Re: Ethernet connection shows wrong broadband provider
@littlelol07 wrote:
Evening
Hi @littlelol07
I would ignore the Network shown in the Q box.
This is invariably an historic connection or the Sky Q mesh.
On the main Q box carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router.
Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
If you have no mini boxes on WiFi soon as it connects go immediately into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
