3
This discussion topic has been answered Discussion topic: Ethernet cable
This message was authored by: Royccc
Ethernet cable
Hi what's the best Ethernet cable to connect to my broadband BT box
have a to about 10m between by and sky box
This message was authored by: nigea99 Answer
Re: Ethernet cable
hi @Royccc
I believe Cat5e cable should be all you need (although I think you would also be fine with older Cat5)
Avatar for Royccc
Re: Ethernet cable
Sorry BT BOX
Re: Ethernet cable
hi @Royccc
Re: Ethernet cable
@Royccc
As @nigea99 suggests, Cat5e (or Cat 6 at most)
The stuff to avoid is copper clad aluminium cable (CCA) which shouldn't claim to qualify for a Cat rating.
