Discussion topic: Error
This message was authored by: AndreaE1
Error
Hi. I have constant MR102 message. The system has been reset 100's of times. It appears this system is not fit for purpose. Do you have a solution? The reboots do not appear to work. Can someone arrange for an engineer to visit?
Re: Error
@AndreaE1
Are you seeing this on a mini box? This is usually the result o the mini box not connecting to the main box.
Have you tried rebooting your broadband router then …
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
If that doesn't work you need to contact Sky. We are customers here on a customer ➡️ customer discussion forum where we try to help other Sky customers. I’m afraid you aren’t communicating with Sky by posting on here.
Avatar for AndreaE1
Re: Error
Hi. Tried all of the above many times. Ongoing.
Re: Error
Hi @AndreaE1
Have you carried out a Network reset on your Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
