Discussion topic: Error message displayed
Message posted on 06 Nov 2023 07:38 PM
Problem finding sky QBox
Message posted on 06 Nov 2023 07:45 PM
Re: Error message displayed
Hi @Sutapa_123
Assume this is a Q mini box.
Reboot the mini as above.
