6
This discussion topic has been answered Discussion topic: Error: UH011
This message was authored by: Vic+n+Gaz
Error: UH011
We haven't changed anything, yet on trying to watch Elvis, in UHD in our UHD TV, it's telling us our TV doesn't support Ultra HD. Have checked HDMI leads etc, problem persists.
Please help
Avatar for Vic+n+Gaz
This message was authored by: Vic+n+Gaz Answer
Re: Error: UH011
Yes, we checked all that, all was as should be.... in the end turned everything off and back on 10 mins later and it worked 🙄
This message was authored by: Ecosse
Re: Error: UH011
Check here to double-check that your Sky Q box is still set to the relevant 2160p resolution.
Also, in the case that your TV may have downloaded a software download, check the settings that may have reset its UHD handling.  On my Samsung, it's under Settings > General > External Device Manager > HDMI UHD Color - select the relevant HDMI port for your Q box.
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
This message was authored by: loverboi
Re: Error: UH011
@Vic+n+Gazhi have you checked that the picture resolution  is set to (uhd) in (settings)  (audio/visual) (picture resolution ) hope my advice has helped please leave a thunbs up or mark as answer thanks😁🙂
Re: Error: UH011
Re: Error: UH011
great to hear that the problem is solved😃😁😊
This message was authored by: matty147
Re: Error: UH011
Currently getting the error UH011 message. Everything was fine this morning and then suddenly it switched to 1080 and now when I go to 2160 it says this input on your tv doesn't support ultra hd when clearly it does. Tv is LG C1. Bought a new cable but made no difference.
Re: Error: UH011
Just tired this morning and it switched this time. Very strange but all good.
