Discussion topic: Error Message: There is a technical fault with this channel. Please try again later
Message posted on 05 Nov 2024 04:37 PM
there is a banner at the top of the screen saying There is a technical fault with this channel. Please try later
Message posted on 05 Nov 2024 04:38 PM
Re: Error Message: There is a technical fault with this channel. Please try again later
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Message posted on 05 Nov 2024 07:06 PM
After resetting the setting I cannot get past the " Important information" Accessibility on Sky Q because the online help link does not work on my devices.
Message posted on 05 Nov 2024 07:20 PM
Reset your Q box remote by pressing and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes. However the remote must be pointed directly at the Q box.
Switch your Q box back on and you then you should be able to get past the setup issues.
Once you get the Q box working make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Message posted on 05 Nov 2024 07:24 PM
I tracked down the link, another way and followed your instructions and got to reset the remote control and then I had to switch off and on the SkyQ box and service was resumed Thank You. I have had no service since 15th October.
Sky Q remotes
My Sky Q remote won't control my Sky Q box
1. Check your batteries and buttons2. Check your box3. Re-pair your remote4. Restart your Sky Q box5. Virtual remote
Check your box
If you're still having problems with your remote, check to see if there's a problem with your Sky Q box.
Press the standby button on the front panel of your Sky Q box. The light should either turn from green to amber, or from red or amber to green.
