Discussion topic: Error MROO1 mini box
This message was authored by Audrey11 This message was authored by: Audrey11
Sky Q Mini box won't connect to main Sky Q box even though have good WiFi signal
Re: Error MROO1 mini box
Hi @Audrey11
Reboot the mini as above.
Audrey11
Many thanks for your response - have tried all this but unfortunately still not connecting.
