Discussion topic: Error MR109 on mini box
Message posted on 21 Jul 2024 10:11 PM
I have had this error come up a few times.
I have done all that is recommended and last time I rung sky as I could not get it to work they told me to press reset button on the back it then worked but it's not working this time any help please ? Thanks
Message posted on 21 Jul 2024 10:12 PM - last edited: 21 Jul 2024 10:12 PM
Re: Error MR109 on mini box
Hi @Suknap
Reboot the mini as above.
Message posted on 22 Jul 2024 02:09 PM
I have tried all of this and still not working
