Discussion topic: Error MR109 on mini box
This message was authored by: Suknap
I have had this error come up a few times.
I have done all that is recommended and last time I rung sky as I could not get it to work they told me to press reset button on the back it then worked but it's not working this time any help please ? Thanks
Re: Error MR109 on mini box
Hi @Suknap
Reboot the mini as above.
Avatar for Suknap
I have tried all of this and still not working
