Discussion topic: Error MR104
This message was authored by: ErrorMR104
Error MR104
Shows error  MR104
Re: Error MR104
@ErrorMR104
Help here:
https://helpforum.sky.com/t5/Sky-TV/Error-Codes-on-Sky-Q-and-Glass/ba-p/4017045
Re: Error MR104
@ErrorMR104 wrote:
Shows error  MR104
@ErrorMR104 Have you tried rebooting your main Q box ie
then
reboot the mini box
Re: Error MR104
@caesarome wrote:
@ErrorMR104
Help here:
Hi @ErrorMR104
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
