Discussion topic: Error:MR104
This message was authored by: Lou157
Error:MR104
Followed online instructions and error still showing
Re: Error:MR104
@Lou157 .
I presume this is Sky Q related so as you had put this in the Sky Go forum I have moved it to the Sky Q forum for you.
Re: Error:MR104
Hi @Lou157
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
