Discussion topic: Error MR 204 on all TV
This message was authored by: Sbea57
All TV's are showing error MR  204
Re: Error MR 204 on all TV
Hi @Sbea57
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
This is what it says on the Tips section of SKY Community about the error code Mr 204
Your mini box might be a bit too far from the main box to get a reliable signal from it.
You might need a Sky Q booster between the main box and the mini box to help the signal reach the mini better.
