Discussion topic: Cannot connect sky q to sky broadband
This message was authored by: Seanc1
The sky q box cannot detect the sky broadband
Re: Cannot connect sky q to sky broadband
Hi @Seanc1
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
