Discussion topic: Erroe message.
This message was authored by: Shelbybunnie
Erroe message.
Constnat blue screen error this screen does not support HDCP.
ive reset my tv rest sky box, checked for updates and nothing is helping.
Re: Erroe message.
HDCP errors are normally to do with the HDMI connection. Check that the HDMI cable is properly connected to both the Q box and your TV. Try unplugging it and re-connecting. Also try re-booting both the Q box and your TV to re-engage the HDMI handshake by turning them off at the wall for a minute then power them back on.
If you continue to get the error message then try a new high speed HDMI cable.
Avatar for Shelbybunnie
Re: Erroe message.
Done that even purchased new cables and a splitter. My xbox and switch work fine just the sky Q box which brings up this error message.
Re: Erroe message.
Hi,
Is you splitter a powered one?....as I've use many splitters and the only one that worked for me was a powered hub (from Amazon)
Re: Erroe message.
It is now we had a normal one before but then purchased a powered one still getting that same message.
Re: Erroe message.
Oh dear, not good....I presume you've tried to switching around the hdmi cables into the differing ports?
Re: Erroe message.
Yes done that too. The cable in my sky Q works great for my switch. Honestly I don't know what else to try.
