Discussion topic: Engineer visited - not helpful. Can you help please?
Message posted on 24 Feb 2024 09:07 AM
Hello
I've moved into a house where the OTN is shared across the development. My provider is See The Light. My internet is working. Sky came out to set up my Sky q box. He's got it working so I can watch it but not connected to the internet to watch anything like Netflix. He said it was plugged in but not working and left. What on earth am I supposed to do? He plugged in something from the router to the phone socket and said that might be broken. Unfortunately he walked in saying 'I bet this won't work' 👍. Do I need to call somebody out?
Message posted on 24 Feb 2024 09:22 AM - last edited: 24 Feb 2024 09:27 AM
Re: Engineer visited - not helpful. Can you help please?
Unfortunately there's not a lot of experience with STL installations in this forum, but as Sky owns STL they really should have some idea.
A 'shared' ONT at an address isn't a problem, but multiple routers or more than one Q installation might well be.
Message posted on 24 Feb 2024 09:33 AM
Thanks so much. Even tho STL is part of Sky he just didn't want help. It's always a shame to get the jobsworth one. Ah well... so the network in terms of the development is fine. So it's an issue in my property.
This might seem an obvious question but - I only pay for broadband and not calls. So might the socket where a phone would plug into, not be active? It might just be that isn't working but no idea how/who to check it.
Message posted on 24 Feb 2024 09:35 AM
The only socket it's appropriate for a Q box to be connected to is an ethernet port for network and internet access.
Message posted on 24 Feb 2024 09:40 AM
Photographs of the setup would be useful if the forum will let you post them: the rear of the box, the wall socket and the internet router if the property has one.
For internet access on existing devices, are you just usual WiFi?
Message posted on 24 Feb 2024 09:45 AM
@MaisieK wrote:Thanks so much. Even tho STL is part of Sky he just didn't want help. It's always a shame to get the jobsworth one. Ah well... so the network in terms of the development is fine. So it's an issue in my property.
Perhaps try STL themselves via the contact form:-
Message posted on 24 Feb 2024 09:49 AM - last edited: 24 Feb 2024 09:52 AM
@Anonymous
Judging by their remarkably unhelpful FAQ, probably not ; )
Message posted on 24 Feb 2024 09:51 AM
@TimmyBGood wrote:@Anonymous
Judging by their remarkably unhelpful FAQ, probably not ; (
Yes, I did notice that and thought it prudent to not mention 😉
Message posted on 24 Feb 2024 10:39 AM
Thank you! I have sent them a contact form. Let's see if anything happens!
Message posted on 24 Feb 2024 10:44 AM - last edited: 24 Feb 2024 10:55 AM
There shouldn't be anything connected to any traditional phone socket. The broadband and TV are all delivered over a fibre optic connection aren't they?
So did he connect your Q box to your router?
Edit: oh hang on, do you meant a shared "ONT"? So there's one router for multiple properties, and you just have what, an ethernet socket in yours? When you say phone socket are you sure it wasn't RJ45?
I shall try to attach a photo! Ok. So it's all fine for internet on other devices.
The sky man then attached the cable top left (telephone type) and into the router. He said that socket might not be working and left.
This is what he did at the back of the TV. God knows what the random bit of wire is
Message posted on 24 Feb 2024 10:55 AM
Photos will appear once approved, don't worry.
Message posted on 24 Feb 2024 10:56 AM
I'm getting this message:
Message posted on 24 Feb 2024 10:58 AM
Ok so yes it's an OTN but we have our own routers in the houses.
I don't know what an RJ45 is 😂. I said telephone socket because it looked like one. Oh my goodness 🤦🏻♀️
Message posted on 24 Feb 2024 11:03 AM
@Chodley Images approved 🙂
