Discussion topic: Engineer said Netflix on Sky multiroom won’t work and left can anyone help
This message was authored by: rita+stapleton
Phoned Sky and they talked me through resetting Netflix . Didn't work so sent an engineer. I have BT Infinity.  I have a sky booster.  The rooms are both on ground floor.  Initially worked then failed.  Engineer said it wont work as minibox technology not up to Netflix coming from two rooms away.  Left without  getting multiroom to work.  @RitaStapleton
Re: Engineer said Netflix on Sky multiroom won’t work and left can anyone help
I think netflix doesn't go via the Q (I could be wrong) so that the mini needs a good enough signal direct from the router.
Maybe worth trying ethernet powerline adapters. One each for the Q, mini and router.
