Discussion topic: Engineer required
This message was authored by: BaileyHoney84
Engineer required
I do not have satellite signal and have tried everything. Please can you send an engineer
Re: Engineer required
Hi @BaileyHoney84   I'm afraid that you are not talking to Sky customer services here. This is a public community forum. You need to contact Sky to book an engineer. Is there anything that your fellow customers can help you with?
This message was authored by: Gemini27or
Require an engineer
Engineer required
@Gemini27or wrote:
Engineer required
See post #2
Multiple posts here won't see an engineer...
@Gemini27or
What Sky Q issue do you have? Is it no satellite signal like the OP had?
If so check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
