6
This discussion topic has been answered Discussion topic: Sky Q message ' you need a satellite signal
This message was authored by: McLeanN
I could not access my sky Q so tried reset but only get a message that a need a satellite signal
Re: Sky Q message ' you need a satellite signal
@McLeanN
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
@McLeanN
Avatar for McLeanN
Level 2 icon
How do you restore the satellite signal
Avatar for McLeanN
Level 2 icon
Thanks but how do I restore the signal
Follow the guide.  Chances are you'll be contacting Sky for an engineer...
hi @McLeanN
Do you have your own dish or are you fed by a communal system ?
If the latter then after you have reset your box the chances are that the LNB type is set incorrectly
You need to check/change the LNB type to SCR - this is in an engineer's menu
To access it :
press Home
Scroll to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by the Enter/ select button
you should now get the engineer's menu
Select the LNB Type & set to SCR if necessary
After changing the LNB type power down your SKY Q box and restart it for the change to come into effect
Avatar for McLeanN
Level 2 icon
Thanks Did that and confirmed the setting is SCR Still not getting a signal so have arranged for someone to come and check the dish and communal internal connections
