8
This discussion topic has been answered Discussion topic: EmmyJo
This message was authored by: EmmyJo
EmmyJo
Hi,
On my TV screen It says “No Satellite Signal”
I have a Q Box: Q1TB
In Settings It says “Satellite Signal Locked”
Can anyone help or advise me please.
Re: EmmyJo
@EmmyJo
It should be showing as locked.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Re: EmmyJo
@EmmyJo
Avatar for EmmyJo
Level 2 icon
Re: EmmyJo
Hi, thank you for your help. The house next door has had some scaffolding erected. It is not close to my dish, but I guess this is causing an obstruction. Regards
Re: EmmyJo
Is your dish pointing at it? Sounds the likely cause.
Re: EmmyJo
@EmmyJo  Your latest post on the stream board has been removed as your issue has nothing to do with Sky stream
Re: EmmyJo
@EmmyJo
Ask your neighbour how long it's likely to be up for.
Sky may be able to move the dish but that seems a bit drastic in the short term and you'd be charged in the region of £65 (providing there's a suitable alternative spot for it).
Avatar for EmmyJo
Level 2 icon
Re: EmmyJo
I don't understand what you are advising . I am a 76 year old pensioner, with not much money to spare. Regards
Re: EmmyJo
@EmmyJo
Contact Sky and see what they say. They may send an engineer to check the alignment of your dish which you wouldn't be charged for.
Re: EmmyJo
If you have a tablet, Sky Go should work in the meantime
