Discussion topic: Eccles
This message was authored by: dennis64
Eccles
Keep getting messages on Sky Q. Can't download due to technical issues also messages saying can't record
Re: Eccles
Hi @dennis64
You may have a hard drive issue .
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Avatar for dennis64
Re: Eccles
Hi have have tried all that , looks like a new box
thanks
