1
This discussion topic has been answered Discussion topic: EE broadband upgrade
This message was authored by: ultracell
I recently had my broadvband upgraded by EE to full fibre.
Since then my SkyQ box will not hold onto my internet connection.
I can connect to the inrternet but within a few minutes the internet connection is lost (only 3 ticks in settings) otherwise everything else seems to be working fine.
Any ideas from forum subscribers?
This message was authored by: PandJ2020 Answer
Re: EE broadband upgrade
Usually drops off if being steered to 5GHz.  (Or connecting wirelessly to some mesh nodes)
Ensure the router does not steer connections.  Also, best setup is to have split SSID's (2.4GHz and 5GHz) as Sky will only connect to the 2.4Ghz band.
