Discussion topic: Dying Ethernet socket on 2TB box?
This message was authored by: LeoBlack30
So,  I've been trying to work out why my wifi in the house is so poor and as a side effect I've realised that,  when connected via Ethernet,  all 3 of my Mini's temporarily lose contact with the Main box,  every few minutes,  for about 5-10 seconds at a time.  they all do it in synchrony.
I've isolated each box and using a long lead connected them directly to the router.  I've replaced the cable between the 2TB and the router.
None of this has any effect,  it still intermitently loses contact.
I've  reset all settings on the 2TB, ensured its in Ethernet mode.
Has anyone come across a 2TB box failing in the way?  It's 8 1/2 years old.
Thanks.
Mike
Re: Dying Ethernet socket on 2TB box?
Thanks.Mike
Hi @LeoBlack30
First thing to try is a Reset Settings in the main Q box hidden menu.
With Settings highlighted press 0 0 1 Select..
Avatar for LeoBlack30
Level 3 icon
That was the first thing I did. No joy
Level 3 icon
So just me then 😂
@LeoBlack30 wrote:
So just me then 😂
Hi @LeoBlack30
Who is your broadband supplier and exactly how is each Q box normally connected?
Level 3 icon
Sky full fibre. Boxes are al connect via Ethernet.
Level 3 icon
Just to update.  During my efforts to get this working,  the main box decided to brick itself.  Huge Kudos to Sky for having a replacement box on my doorstep before 9am this morning,  depsite me only "ordering" Saturday even.  Esspecially given the recent weather.
New box is aslo HDR which is a nice bonus.
