Discussion topic: Dutchland box
This message was authored by: Sammymack1967
Dutchland box
My sky says sky dutchland
Re: Dutchland box
Deutchland, not Dutchland
Where did you get it?
Re: Dutchland box
@Sammymack1967  If it's a Sky Q box obtained from Sky it won't be displaying Sky Deutschland, it's likely to be your TV showing this name on the HDMI input on your TV.
Re: Dutchland box
Ah yes good suggestion. Isn't that device identity info transmitted over CEC? Or is it just a code the TV looks up in some internal database?
