Discussion topic: Downloading Channel5
This message was authored by: Roger93
Message posted on 01 Dec 2025 09:47 AM
The message I get says I need the required subscription to download Channel 5. Why?
Find out more
Message posted on 01 Dec 2025 10:06 AM
Re: Downloading Channel5
hi @Roger93
Do you have the HD add on ?
there is a quirk with C5 (& C4 I think) in that you can watch & record from the live HD channel but need the HD add on to download & watch in HD
If you do not have the HD add on best to change the default download preference to SD:
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
