6
This discussion topic has been answered Discussion topic: Download dosaster
This message was authored by: Rosie510
Download dosaster
I can record movies from channels 301-328 but cannot download directly from sky cinema, just doesn't do anything. Can this be resolved
This message was authored by: GeoffH Answer
Re: Download dosaster
This is an issue discussed in detail here: https://helpforum.sky.com/t5/Sky/Sky-catchup-unusable/td-p/5095700/highlight/false
Long story short, it seems that TalkTalk's DNS servers are sending traffic to a backend content delivery network (CDN) that is blocking access for some reason. A workaround that seems to work (for now!) is to change the router's configuration to use Cloudflare's DNS servers (1.1.1.1 or 1.0.0.1). Make a note of your existing router configuration for DNS before making changes so you can put them back in the future if required.
If you are not confident changing your router configuration then I advise waiting for Sky and/or their CDN and/or TalkTalk to fix the problem.
Hi @Rosie510
Have you tried rebooting your Q box?
Avatar for Rosie510
Level 0 icon
I have turned box off (several times) but to no avail I'm afraid
Hi @Rosie510
You can also just change the DNS server on the Q box itself and leave the router alone.
You can, but that requires using manual IP address configuration and you need to ensure you choose an IP address that is on the same network as your router, but outside of the range the router might assign to other devices using DHCP. If you use the same address that had been assigned via DHCP then there is a (small) chance that some time in the future the same address may be assigned to another device. That would be bad.
