Discussion topic: Downgrade
This message was authored by: Sds2
Downgrade
How do I remove sky sports and sky cinema
Re: Downgrade
Either online or on the MySky app, but it's often better to call Sky. You may be locked into a contract on either or both of them, in which case removing them may not be possible.
Re: Downgrade
@Sds2
Cancel PART of your TV package:
You need to contact Sky giving 31 days notice. If you have 'in contract' discounts you may not be able to remove them, because the discounts were provided on the understanding you’d be paying for the full period. Also make sure cancellation of a certain add-on doesn’t affect another discount.
You may be able to remove it via this link which includes a message option (usually available between 9am & 7.30pm) or by calling using the number that should appear.
https://www.sky.com/help/articles/change-your-package-2-t2#downgrade
▪️I AM NOT A SKY EMPLOYEE ▪️
