Discussion topic: ‘Do not have internet connection right now’ error message on Tv
Message posted on 04 Oct 2023 06:08 PM
I have gone to settings and selected Network Setup
Tried to connect to Sky broadband router held the WPS button but it does not connect
Message posted on 04 Oct 2023 06:16 PM
Re: ‘Do not have internet connection right now’ error message on Tv
Hi @Alison122
Are you sure that you pressed the Sky Router WPS button and not the reset button.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
As you are on Sky broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
WPS button location
Message posted on 04 Oct 2023 06:20 PM
Thank you, I did press it on the sky q box, I'll try the router now
@oldfella thank you, it's working now
