Discussion topic: Disney plus log in problem
This message was authored by: tj68
Got Sky Q back again after a 2 year break already have disney plus sub with disney direct, when I log in put my disney plus email in sends me a code which I input on the screen then it asks me to create a new password? I can not proceed any further as I do not want to create a new password as already have one that I been using for years? Help anyone please
Re: Disney plus log in problem
hi @tj68
When you say input the code onthe screen which device are you using to do this ?
Have you logged into your Disney+ device on that device before entering the code ?
Avatar for tj68
Level 4 icon
Put the code on screen on the sky q box
hi @tj68
The code should be put into a page on another device :
Disney + code
Avatar for tj68
Level 4 icon
Not correct see ss showing what I have to do on the sky box in order
Moderator note: Removed picture including personal details.
hi @tj68
in which case are you sure you are using the same Email address you have already set up your Disney + subscription with ?
Avatar for tj68
Level 4 icon
Yes entered it 30 times only have 1 email
Hi @tj68
The following is taken from the Disney plus help link
https://help.disneyplus.com/en-GB/article/disneyplus-en-us-log-in
If you’ve already subscribed to Disney+ or a Disney Bundle plan, you’re only a few steps away from enjoying the best shows and movies that we have to offer. In order to watch all of this content on your TV, you’ll first need to activate Disney+, Hulu, and ESPN+ on that device.
Follow the steps below to activate Disney+ and start streaming on your smart TV or other TV-connected device.*
  1. Launch the Disney+ app on your smart TV or TV-connected device
  2. Select Log In
  3. Visit DisneyPlus.com/begin from a computer or mobile browser
    • If you’re having trouble accessing this link, please switch to an incognito or private window on your browser and try the link again
  4. Enter the 8-digit code that appears on your TV screen
  5. Follow the prompts to log into your Disney+ account on your computer or mobile device
  6. Once logged in, you’ll see your TV screen refresh with a successful activation prompt
  7. Select Start Streaming to enjoy Disney+ content on your device
Keep in mind if you’re ever logged out of the Disney+ app on your smart TV or TV-connected device, you’ll need to follow the above activation steps again before streaming.
This message was authored by: best+of+the+best
@tj68 I also have Disney+ direct with Disney
I've replicated what you have done by logging out of my Disney+ account.
You enter your email then you are sent a code once the code is entered you get the Create a new
Password if you don't want to create a new password just use your old password
Every time you sign out of your Disney+ account you enter your email you get a code enter code use old password straightforward really.
This message was authored by: mossian2000
This madness happened to me too and I found this thread.
My solution: It wouldn't allow the last password to be used.
I changed the password by just deleting the last letter of the password I had. All fine, password changed and I could log into Sky app with the code generated to my email.
I immediately went back to the Disney plus site and went to security and change password. I changed the password back to my old password - it now wasn't the "last password" so it let me do that.
It's stupid but it means I'm now logged into Sky app and I don't have to change all my other devices.
This message was authored by: Guryudgs
I have the exact same problem, did you manage to get this sorted?
My hack worked
