14
This discussion topic has been answered Discussion topic: Disney+ app won't connect
This message was authored by: LIONLADY
I cannot connect to my Disney+ app on my Sky Q box, it just stopped working and shows an error code of 1026, saying it can't connect to network. Everything else is working okay. I have unplugged my Q box to reset it but it still doesn't work, any ideas please?
Avatar for LIONLADY
This message was authored by: LIONLADY Answer
Re: Disney+ app won't connect
I think I had to delete the app and reinstall it. It was either that or I had to have a new Sky Q box 😊👍🏻
Start with an app refresh and see how it goes from there, although Disney+ is pretty buggy on Q at the moment.
To enter the hidden menu press Home and navigate down to Settings but do not select Settings.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
https://help.disneyplus.com/en-GB/article/disneyplus-en-uk-error-1026
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Avatar for LIONLADY
Okay thank you, I have tried the steps that you have said above, last night and still nothing, though hopefully it may start back up soon, as it dies say 24hrs. It's strange how it's working on all of the other devices, just not on Sky Q. Thank you for your quick response, it's much appreciated. 😊👍🏻
Has it ever worked?
Is your Sky Q up to date?
https://www.sky.com/help/articles/updating-sky-box-software-sky-q
I am watching "Will Trent" currently via the app on Sky Q for testing and apart from the usual slowness in the menus, it is working OK so far.
My Sky Q is on Q280 and the Disney+ app is 25.2.0+victor.04 (p) if it helps (Settings > Help > Diagnostics).
Avatar for LIONLADY
Thank you for your reply. It is updated now, but sadly still not working, for Disney+.
This message was authored by: Annemarie22
I am getting the same issue, cannot even get on the app to activate it as it now comes with sky. I have refreshed apps, turned off and back on and also reset but still black screen with error 1026 telling me to exit the app and try again
everything else is working ok
Avatar for LIONLADY
Oh i was thinking how can i delete the app and reinstall, did not see an option?  Thank you for replying
Avatar for LIONLADY
Could possibly be a case of logging out on a device and then logging back in, sorry i can't  be more helpful
It is not yet included for free anyway
Avatar for LIONLADY
There is a section in the SkyQ settings, where you can update your apps, maybe that would help? Or if you can try to login to disney+ on a computer maybe, Good luck 🤞
This message was authored by: Vikb3479
Im having the same issue . I've been on settings and done refresh apps seeing if that helps driving me mad wanted to watch rivals
This message was authored by: MrsVW2013
I'm having actually the same and I was desperate to watch Rivals.
Disney + not working
I have tried repeatedly to get Disney + to open through sky q. It keeps showing an error code of 1026-AUTH_SERVICE_INIT_FAILURE
I've done an app refresh, turned off router. Any other suggestions would be gratefully received! Thank you.
