7
This discussion topic has been answered Discussion topic: Discovery +
This message was authored by: Michelle1962
Discovery +
So I can view Discoery + on my main box, yet not on the mini box, spoken to two technicians for 2 hrs at a time, yet still not resolved 🙈
Re: Discovery +
Hi @Michelle1962
First thing to do is to check your software on all boxes to make sure they are on the latest Software.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
Any Q box (including minis) may require a manual software update at times.
For example a replacement Q box or mini or any box that is powered off when an update is released.
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
All Q boxes and minis should be on the same software version.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software
If the Software is all up to date.
Reboot the mini as above.
Re: Discovery +
Hi @Michelle1962
Avatar for Michelle1962
Re: Discovery +
Thank you so so much, I did the update of software on both box's, I now have a happy husband 🙂
can't believe I spent over 4 hrs on the phone to technical department,but they definitely need to make sure that when speaking to a customer that they  are on the main box & not the mini one!,
Re: Discovery +
Update, gone to watch discovery + now back to where we were in the first place, not working 😡
Re: Discovery +
Did you do the reboot of all Q boxes as per my post @Michelle1962
Re: Discovery +
I did all what you've said, but now we are stuck on step 2 of reset on the mini box, it will not go any further, just keeps saying do you have any other sky product that you can connect too 😡
Re: Discovery +
Hi @Michelle1962
Reset your mini remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the mini box.
Switch your mini box back on and you then you should be able to complete the Setup
Once you get the mini working make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Re: Discovery +
Update, did all what you've said, still doesn't work ok mini box, I just give up
