cancel
Showing results for
Search instead for
Did you mean:
Discovery+ with Sky Q Essentials
SOLVED
Reedie19
Level 1
Solved!
I want to view Eurosport via Sky Essentials, which I understand requires a Discovery+ subscription.  When I search for info, I'm only told that I can't get free Discovery+ (with Essentials).  However I'm prepared to pay to add it.  Is that possible?
1 ACCEPTED SOLUTION
Accepted Solutions
oldfella
Level 16
Solution
Re: Discovery+ with Sky Q Essentials
@Reedie19 wrote:
Hi @oldfella, since posting my initial response I've decided to accept your suggestion.  Recording isn't such an issue with Eurosport as much of their offering can be viewed on demand.  Thanks again.
Hi @Reedie19
You cannot record Discovery plus as it is purely a streaming App. same as all Apps which are stream only)
View solution in original post
4 REPLIES 4
oldfella
Level 16
Message contains a hyperlink
hi @Reedie19
No reason why you cannot subscribe to Discovery plus direct and not through Sky
See following link
https://www.discoveryplus.com/gb
Not sure what package you need to watch Sports
Reedie19
Level 1
Thanks for the suggestion @oldfella. I'd hoped to integrate it with Sky so I could record programmes on the Q box. Could I use the record function if the channel is a separate app?
Reedie19
Level 1
oldfella
Level 16
Solution
Hi @Reedie19
