Discussion topic: Discovery+ tennis viewing interrupted
This message was authored by: GrumpyMan
When watching some replays ie the Djokovic match there is a line of tennis balls across the screen, kinda like a watermark on documents.
Anyone have any ideas as to why or how I can remove it?
thanks for any advice
GM
This message was authored by: Devaman
Re: Discovery+ tennis viewing interrupted
Good question. It's very annoying. And it's similar on the football coverage with timelines which won't go away.
That is the timeline function that selects points of interest through the match, like winn8ng interview, set points, break points etc.
It is shown on replays and when using the Watch from Start, during a live match.
When playing the match, just hit the dismiss key on your Sky remote.
Make sure that you have dropped down to the pause/playff/rew bar, below the timeline, when doing dismiss, otherwise you may drop out of the match.
Discovery have beeen doing it like this with some of their other Sports for sometime, it's not unique to the Tennis.
This message was authored by: Victoria64
They seem to be there to watch hot shots, break points etc. They were annoying me too but I found a way to turn them off by pressing on the rectangle with three balls on the right hand side of the screen.
This message was authored by: Bigdeg
Press pause first
This message was authored by: DH47
I must say it makes it impossible to watch the tennis. But I can't find how to turn it off
