Discussion topic: Discovery @ TNT
This message was authored by: Fredcat89
Discovery @ TNT
I need help syncing my discovery plus account with my tnt sports subscription. Both through sky
Re: Discovery @ TNT
Have you been through the process here to activate and set up your subscription?
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Avatar for Fredcat89
Re: Discovery @ TNT
Re: Discovery @ TNT
Do you not remember your Discovery+ login details then?
If not, go to the app (preferably on a mobile device), and reset your login.
Reset…Reset…
