Discussion topic: Disc drive problem
This message was authored by: Willow+2020
Disc drive problem
Our sky is saying that we have a problem with our hard disc drive, we can't see our recordings or rewind on live tv
Re: Disc drive problem
@Willow+2020 you try rebooting your main Q box ie
but normally hard drive problems are terminal and end up needing the box replaced best to contact Sky now
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Coonkit
My TV is saying hard disk problem. I can't record pause or watch a recording. I switched it off twice but still not working
Follow the Sky help advice here to reset your hard drive and/or request a replacement Sky Q box online from the link in the same article;
Sky Q Hard Drive error messages | Sky Help | Sky.com
@Coonkit
If as the result of the link provided by @lettice Sky suggest a box swap at the doorstep, remember to remove the viewing card from the faulty box before it disappears into a van.
▪️I AM NOT A SKY EMPLOYEE ▪️
