Discussion topic: Direction buttons
Message posted on 20 Apr 2025 03:01 PM
Direction buttons
I have no TV listings and direction buttons on remote don't work
Message posted on 20 Apr 2025 03:09 PM
Re: Direction buttons
@RP721
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
