7
This discussion topic has been answered Discussion topic: Different menus
This message was authored by: Shellc83
Different menus
Is anyone else's menus different on their main sky Q box and the mini box?
On the main box it's like the picture below.
But on the mini box the delete button, etc is in the right hand side
Re: Different menus
@Shellc83 wrote:
That would make sense.
Yesterday I went to watch Disney+ for the first time on the mini box but it wouldn't work. But it does on the main box
how do I update the mini box?
Hi @Shellc83
First thing to do is a Software Update to make sure the box is on the latest Software.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
Any Q box (including minis) may require a manual software update at times.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software
Re: Different menus
hi @Shellc83
What software version is on the mini ?
Home - Settings - System Info - Software Version
Re: Different menus
hi @Shellc83
@Shellc83 I agree with @nigea99 that looks like your mini box is on a very old version of the software as Sky havent had the menu option at the right hand side for years
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Shellc83
Re: Different menus
Re: Different menus
hi @Shellc83
To check & refresh if needed follow all the steps on this link (skipping any that are OK):
Software/Apps Update
Re: Different menus
Hi @Shellc83
Avatar for Shellc83
Re: Different menus
All sorted!
Thank you so much.
It's weird really why it had the old software as it was only installed 2 weeks ago
Re: Different menus
@Shellc83 wrote:
All sorted!
Thank you so much.
Hi @Shellc83   That is the reason why it was still on an old software version. It needed updating from the manufacture version.
