08 Dec 2023 06:45 PM
Hi, I'm new to Sky Q and from my research deleted recordings from the same series should all group together to make it easier to delete all the episodes but as you can see from my photo all my "Help! We bought a village" episodes are showing as individual listenings and are not grouped together so it takes a long time to delete.
08 Dec 2023 06:48 PM
If you go to to recordings Manage and then Disk space you can delete delete all episodes in a series
08 Dec 2023 06:55 PM
Hi, yes but if you look at my image they are not grouped together so I have to delete every one individually
08 Dec 2023 07:01 PM - last edited: 08 Dec 2023 07:04 PM
The image you have posted is from the Manage Recordings which indicates you have already deleted them.
There is no option to permanetly delete aka Delete Forever multiple recordings
Very few people ever feel the need to actually use the delete forever option as once deleted (from the normal options) the houselkeeping does a very good job
BTW To just ordinary delete (& not delete forever) you can delete grouped programmes from the Disk Space menu option & from the Sort By - A-Z option
I had to in delete them so they went back into the disc space folder then was able to delete all so thank you.
08 Dec 2023 07:08 PM
Thanks for the info and now sorted. Can't believe they removed the bookmark feature on Sky Q but hey ho.
08 Dec 2023 07:11 PM
Technically didn't remove - just never implemented on Q - Bookmarks in recordings is probably the one feature I still occasionally miss on Q
