Discussion topic: Delay
This message was authored by: Shann123
Delay
Hello all,
I'm having a bit of a kerfuffle. For context, I have a SONY TV and Soundbar system. The soundbar is connected to the TV via an Optical Cable. For some reason, when I am changing a channel on my SKY Q box, there is a delay of around 3 seconds, and the sound starts. There is no audio sync issue, it's all good, but the delay is quite infuriating!
Does anyone know of a way to fix this or remove that 3 second delay before the audio starts?
Many Thanks
Re: Delay
It's most likely the soundbar that's the 'issue'.
It's the time taken for the soundbar to recognize the audio stream, decode it and output it from an interrupted signal.
Can you not use HDMI?
Avatar for Shann123
Re: Delay
Well there's no HDMI port on the Soundbar, so I am unable to do that. The other devices connected to the TV work perfectly, with no delay at all!
This message was authored by: ThePope27
Re: Delay
Hi @Shann123,
I have this when going between YouTube and normal Sky Q channels, go into the audio visual settings then under both HDMI and Optical set it to normal instead of Dolby Digital or Dolby digital plus.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
This message was authored by: CameronMcG58
Re: Delay
I have a Sony TV as well and i had the same problem, so i switched it to a hdmi cable and it was fine.
