Discussion topic: Dead sky Q box now obsolete charging me £99 for new box or wait 3 week on an engeneer to come to fix
Message posted on 25 Oct 2023 01:42 PM
Dead sky Q box now obsolete charging me £99 for new box or wait 3 week on an engeneer to fix/replace obsolete box probably costing sky more ??
Message posted on 25 Oct 2023 01:45 PM
Re: Dead sky Q box now obsolete charging me £99 for new box or wait 3 week on an engeneer to come to
Replacing a faulty Sky Q box does cost anything. If you're being charged it sounds like you're upgrading your box to HDR capable perhaps.
Message posted on 25 Oct 2023 01:48 PM
Yes new box cost mines now obsolete. Mine requires an engeneer visit to replace/repaire probably cost more for engeneer to be sent to fix
Message posted on 25 Oct 2023 01:50 PM - last edited: 25 Oct 2023 01:51 PM
@Newpete wrote:Yes new box cost mines now obsolete. Mine requires an engeneer visit to replace/repaire probably cost more for engeneer to be sent to fix
Obsolete? I doubt it.
All hardware is loaned but would be replaced for free if failed. Upgrades to later features (UHD/HDR) does incur a one-off charge.
Message posted on 25 Oct 2023 01:52 PM
An 'engineer' doesn't 'fix' a box: they just swap them out.
You shouldn't be charged anything in a like-for-like replacement.
Message posted on 25 Oct 2023 01:54 PM
I'm not sure what point you are trying to make. Sky Q boxes are loaned to you and if they develop a fault will be replace at no charge via either an engineer visit or a doorstep box swap. If you upgrade to a box, for example that is HDR capable from an older box that isn't compatible that could incur a charge.
Message posted on 25 Oct 2023 02:17 PM
Point I'm making it's going to take 3 weeks for engeneer to come swap/fix my sky q box. If I upgrade can get one posted out for £99. My point is engeneer visit will probably cost more than new box.
Message posted on 25 Oct 2023 02:21 PM
But not to you. Engineer visits aren't chargeable.
Message posted on 25 Oct 2023 02:37 PM - last edited: 25 Oct 2023 02:41 PM
I'd suggest calling back and politely but firmly pointing out that's an unreasonable period to wait, and that loaned equipment should be replaced free of charge.
The only technically obsolete box is the v1 2TB which can do UHD but not HDR. If Sky cannot replace that like-for-like then they should replace for free with an HDR model, rather than applying the charge levied for voluntary upgrades.
