This discussion topic has been answered Discussion topic: Crunchyroll not loading
Message posted on 30 Jan 2026 10:30 PM
Message posted on 03 Feb 2026 06:00 PM
Hello Everyone,
We're sorry you have been experiencing problems with the Crunchyroll app. We received an update from Crunchyroll regarding this issue;
''We recognised this yesterday during our launch of in app version 14. It was affecting older devices on Sky and Samsung mainly. We pushed a fix this morning that fixes it. This has now been deployed for Sky''
Sorry for any inconvenience caused by this and if you do have any further issues with the app then please let us know.
Thanks, Jason-
Message posted on 31 Jan 2026 10:40 AM - last edited: 31 Jan 2026 11:59 AM
Re: Crunchyroll not loading
@Arronl Crunchy Roll is not available on Sky Go as Sky Go is itself a PC/Mobile app.
What device are you having an issue with Crunchy Roll?
Message posted on 31 Jan 2026 09:57 PM
Crunchyroll not working on Sky Q
Is anyone aware of any known issues with the Crunchyroll app on Sky Q? I can't get it to load on either my Q box or mini boxes.
When opening the app i get an error screen with the code WCP-UN-0 which asks to check the connection. My devices are definitely connected to the internet and all other apps work fine.
I've exhausted all the troubleshooting guides I can find, both on the Sky and Crunchyroll websites. I've tried restarting all the boxes, I've checked my software is up to date on all boxes, I've done the app refresh and waited the recommended 24 hours but still no luck.
I've encountered the same error code before on smart TVs and solved it by uninstalling then reinstalling the app. I thought an app refresh on Sky Q would have the same effect as this but I'm not sure it actually did anything.
Anyone know if there's a way to force an app to reinstall or have any suggestions on what I could try next?
Message posted on 01 Feb 2026 09:09 AM
Update:
I did a factory reset on my mini boxes this morning and that has fixed it!
I assume the same will work on my main q box bit I'm not gonna try that yet as I know this will delete all my recordings.
Message posted on 02 Feb 2026 06:11 PM
Black screen for crunchyroll
Crunchyroll isnt working on my box I have reset it and still not working
Message posted on 02 Feb 2026 06:31 PM
I too get a black screen when I select the Crunchyroll app
Message posted on 02 Feb 2026 07:22 PM
There is a crunchyroll app on sky q. Think that's what's not working as I have the same problem
Message posted on 02 Feb 2026 07:23 PM
Mine is on a sky q box and the rest didnt work. It just has a black screen and nothing happens
Message posted on 02 Feb 2026 09:00 PM
Mine is sky q and minny box
Message posted on 02 Feb 2026 09:01 PM
Yer mines not working on my main sky q box or mini. Just get a black screen. Crunchyroll have just released an app update so guess that's what's causing the issue
Message posted on 02 Feb 2026 09:09 PM
Im running into the same problems. Did a power cycle on my sky Q and no change
Message posted on 02 Feb 2026 10:50 PM
+1 on sky Q
Message posted on 03 Feb 2026 02:53 AM
Hi, how do you do factory reset, please?
Message posted on 03 Feb 2026 09:31 AM
Hi, I did a factory reset, but it did not solve the issue
Message posted on 03 Feb 2026 12:10 PM
Sky sent a replacement Q box still doesn't work just a black screen
