Discussion topic: Cox
Message posted on 04 Jun 2024 03:26 PM
Cox
Can a sky q mini box be too far to connect to main box. Non sky WiFi is good in both rooms .
Message posted on 04 Jun 2024 03:34 PM
Re: Cox
@chris+cox63 wrote:Can a sky q mini box be too far to connect to main box. Non sky WiFi is good in both rooms .
Miniboxes connect to a WiFi mesh network created by the main Q box. If the boxes are too far apart then you will have problems.
Message posted on 04 Jun 2024 05:59 PM
Re: Cox
@chris+cox63 as @Padam_Padam alludes to your mini boxes do not connect to your non Sky wifi but instead connect to the mesh from the main Q box so yes they may be to far so you may need Q boosters to boost the signal to your mini boxes
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 04 Jun 2024 06:12 PM
Re: Cox
Hi @chris+cox63
Reboot the mini as above.
