Discussion topic: Control volume from auna amplifier with the sky remote
Message posted on 01 Aug 2025 11:37 AM
Hi all
I have trying to use the sky remote to control the volume from the Auna amplifier.
The Q speakers are connected to the amplifier.
And the amplifier is connected to the Sky Q by an optical cable.
Thank you
Message posted on 01 Aug 2025 09:20 PM
Re: Control volume from auna amplifier with the sky remote
Does that amp not show up in the list when you go through the Q remote pairing process?
Message posted on 01 Aug 2025 09:32 PM
No, unfortunately doesn't.
Message posted on 01 Aug 2025 09:38 PM
You might be out of luck unless you can find another brand that uses the same IR codes, often there are multiple brands made in the same factory under license.
Message posted on 05 Aug 2025 08:07 AM
Thank you. I've had to change my Amplifier
