12 Jan 2024 08:52 PM
Why when I'm watching a series on record (Only Fools and Horses, for instance) does the 'Continue' feature hardly ever work? If I've watched, for instance, episode 3 of series 2, going to Recordings > Continue should bring up episode 4 of series 2. But rarely is this ever the case. More often than not the system will just pick a (seemingly) random episode.
12 Jan 2024 08:54 PM
Hi @Bill1968
The Continue option is normally used to pick up previously part watched Recordings.
12 Jan 2024 09:05 PM - last edited: 12 Jan 2024 09:29 PM
I (& think some others likewise) have usually found the Recordings - Continue Section to be very unreliable.
I have known it to point to the next episode for episodes I have not completed and for others point to episodes I have completely watched and deleted !
My advice is do not use this section unless you really know it points to the correct episode.
Also I recommend using the buttons above epiodes in the Most Recent' section with great caution also - they in particular seem to point to the next episode when near (but not at) the end of an episode - I advise always using the buttons below the episodes instead even though it is more key presses
12 Jan 2024 09:28 PM
Hi, thanks for the answer. I did wonder this, but this method does (occasionally) select the following episode, so I assumed this was the intention.
12 Jan 2024 09:30 PM
Thank you. Glad it's not just me then.
NB: The forum's reply function doesn't appear to be working, as it's posted my replies separately and not beneath the person to whom I was replying.
12 Jan 2024 09:35 PM
BTW to tag people you just type the @ sign and the first few letters & the ids should be listed.
To Quote a reply you need to press the '' icon above the text box
12 Jan 2024 11:18 PM - last edited: 12 Jan 2024 11:19 PM
@Bill1968 wrote:Thank you. Glad it's not just me then.
You have to hit the quote button otherwise the forum gives no clue what you were replying to.
Rubbish, isn't it.
Yours were obvious from context luckily 🙂
12 Jan 2024 11:51 PM
Ah! Thank you @nigea99
12 Jan 2024 11:52 PM
Rubbish, isn't it.
Unusual to say the least!
