Discussion topic: Contacy Numbers
This message was authored by: NR637
Contacy Numbers
Hi,
I am a Sky customer in Ireland.
What is the best telephone numbers to contact Sky to speak with a real person.
Re: Contacy Numbers
@NR637
You can call Sky free by dialling 150 from a Sky Talk landline or a Sky Mobile, alternatively you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
**** ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.***
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you here to the forum. Stay on the line as long as possible and don’t hang up. If necessary say nothing when the automated system asks you what your call is about as it should then route your call into a queue for the next available agent.
If you explain the issue someone here may be able to help and save you a call.
▪️I AM NOT A SKY EMPLOYEE ▪️
