Discussion topic: Constant technical problems between main sky box and mini box
This message was authored by: James02
I am constantly unable to watch any sky as there is a technical problem between my main sky box and mini box every day.
Re: Constant technical problems between main sky box and mini box
@James02 not sure what you have already tried but
Have you tried rebooting your main Q box ie
then
rebooting your mini box
