Discussion topic: Constant issues with connectivity on sky q
Message posted on 20 May 2024 01:02 AM
I keep having connectivity issues with my sky q my main box decides to throw off the wifi so then i need to reconnect it with ssid and password and my mini box keeps dropping off the network everyday spoke to customer service countless times who seem to be no help at all. Has anyone got any advice of what i can try to stop it from disconnecting ive tried network resets factory resets to no avail
Sky Glass Gen 2 43” Volcanic Grey, Sky Live, x1 Sky Stream Puck, Sky Broadband Superfast (Part Fibre), Sky Max Hub (SR213), Sky Ultimate TV, Sky Cinema, Sky UHD & Dolby Atmos, Whole Home, Ad Skipping. Former Sky Q Customer
Message posted on 20 May 2024 07:46 AM
Re: Constant issues with connectivity on sky q
Hi @xchrissyboix23 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any Mini boxes?
Message posted on 22 May 2024 12:19 AM
Hi @Quoman7 sorry for the late response i tried all of those steps to no avail but what seems to have stopped the issue is going onto my bt smart hub 2 admin settings and changing the 5ghz channel to 44 im currently monitoring it at the moment but all is looking good
Message posted on 22 May 2024 07:20 AM
@xchrissyboix23 If you still get connectivity problems try turning off "smart connect" on your BT router?
