Discussion topic: Connectivity
Message posted on 20 Oct 2024 10:10 AM
Connectivity
I keep getting the message "you can't watch TV at the moment as there is a connectivity problem".
its on a mini box.
but the main SkyQ box cuts out when streaming.
(I've re booted everything including wi fi hub 3 times).
Message posted on 20 Oct 2024 10:29 AM
Re: Connectivity
its on a mini box.
Hi @IMc2
Once the main Q box is back up and running
Carry out aa Network Reset on the mini.
Message posted on 20 Oct 2024 11:32 AM
Re: Connectivity
Hey, thankyou
i gave all that a go but still no luck. Will have to reach out to Sky direct.
thanks for the response, it was helpful to give something else a try. 👍
