Discussion topic: Connectivity problem
This message was authored by Paul59A This message was authored by: Paul59A
Tv screen showing all programmes
cannot get any program due to connectivity problem
Re: Connectivity problem
Hi @Paul59A
Assume this is your main Q box?
Try a Network Reset found in Q box Home - Settings - Setup - Network.
