Discussion topic: Connectivity issues
This message was authored by: kev9187
Connectivity issues
My main sky q box keeps dropping connection to wifi & sky signal.
ive reset & reactivated several times in the past hour just for it to drop again.
im quite clued with the whole system, bar resetting the hard drive is there anything else i could do?
this obviously also them affects my mini boxes too when the main box drops out.
TIA
Re: Connectivity issues
TIA
Hi @kev9187
Who is your Broadband supplier and how far is your main q box from your router?
Avatar for kev9187
10 feet at a maximum. And it's with BT
Have you considered Ethernet connection or Powerline @kev9187
Avatar for kev9187
@oldfella @Never had a issue with it until now & I've had Q since day 1 pretty much.
so not really needed too.
I've got 3 mini boxes 1 of which is cat 5/6 wired connection. But obviously there all connected to the main box which keeps dropping off.
Hi @kev9187
Have you completed the following procedure?
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
If you have there is not a lot else you can do.  As I'm sure your aware WiFi can be unpredicable and any change in your own or neighbours Devices could cause issues.
The only other suggestion I can make is to try and obtain a Sky Q WiFi booster to connect to your router by a short Ethernet cable.  Your main Q box may then connect to this by WPS which may be more reliable
Avatar for kev9187
@oldfella @Yes mate tried all that.
yes got a WiFi booster both sky for the Q and BT for the WiFi.
I'll just have to restart the hard drive & take note on what recordings I'll lose.
thanks for your time & answers
Hi @kev9187
If you have a Sky Q booster I would try this connected to your BT router by a short Ethernet before you delete everthing from your hard drive
