Discussion topic: Connectivity issues
This message was authored by: Reena121
Connectivity issues
Hello. I've been having connectivity on my sky. All my other devices are working so it's not my internet.
they sent me a new sky box and it's same issue Netflix and YouTube are very slow
Re: Connectivity issues
Hi @Reena121
Have you correctly carried out a Network reset on the Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
